[GRASS5] GRASS 5.7 updated tcltkgrass 4.01 and scripts
Markus Neteler neteler at itc.it
Sun May 16 09:22:29 EDT 2004
On Sun, May 16, 2004 at 01:09:38AM -0700, Michael Barton wrote:
> I've updated tcltkgrass for GRASS 5.7. It is available on my web site
> <http://www.public.asu.edu/~cmbarton/grass.htm>.
> tcltkgrass 4.01 covers some of the recent additions to 5.7, including
> r.fillnulls (I recently updated to 5.7), r.in.mat, r.out.mat,
> v.surf.rst, v.surf.idw, i.fusion.brovey (a new script by Markus to do
> Brovey transformations and pan sharpening for Landsat ETM, Quickbird,
> and SPOT imagery), and r.mapcalc.tcl (the 5.3 r.mapcalc GUI I updated
> to 5.7).
Michael,
thanks for your efforts.
But the package is not in sync with the version in CVS.
It seems that you continued with an older version.
> All the updated scripts I've done for 5.7 are also in the package,
> along with the tcltkgrass startup program (for $GISBASE/bin) and a
> version of Init.shb (for $GISBASE/etc) that will start tcltkgrass
> automatically on GRASS launch along with the display manager.
> Much of this has recently been uploaded to the CVS. However, it would
> be a big help if you could test these updates.
Please do not upload to CVS. First a careful revision is needed.
I'll send a list of obervations to you later.
Markus
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
