[GRASS5] Re: grass5 digest, Vol 1 #1162 - 9 msgs
Michael Barton
michael.barton at asu.edu
Tue May 18 15:52:17 EDT 2004
Jens,
Thanks for the reply. I changed the symlink for libz.dylib from
libz.1.dylib to libz.1.1.3.dylib. This seemed to do the trick. However,
now I've hit a different snag.
Make crashes with the following error
-L/sw/lib /sw/lib/libqt-mt.dylib -L/usr/X11R6/lib -L/lib -lresolv -lGL
-lXmu -lXrender -lXrandr -lXcursor -lXinerama -lXft -lfreetype
-lfontconfig -lXext -lX11 -lSM -lICE -lXt -L/usr/local/grasslib/lib
/usr/local/grasslib/lib/libgdal.dylib -L/usr/local/grasslib/src
/usr/local/grasslib/lib/libproj.dylib -lm -lmfhdf -ldf -lsz -lz
-lpthread -ldl
ld: warning -L: directory name (/lib) does not exist
ld: can't locate file for: -lz
make[4]: *** [qgis] Error 1
make[3]: *** [all-recursive] Error 1
make[2]: *** [all] Error 2
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
I can't figure out what it is looking for with -lz. Any idea?
Also, I went to irc.freenode.net. This took me to the FreeBSD Project
page. No information about qgis there. If this refers to an IRC chat
session, I'm afraid I'm don't know what I need to do to participate in
this. Also, here in Arizona, I'm in a very different time zone from
Europe.
Thanks
Michael Barton
______________________________
Michael Barton, Professor & Curator
School of Human Origins, Cultures, & Societies
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
On May 18, 2004, at 3:01 AM, grass5-request at grass.itc.it wrote:
> From: Jens Oberender <grass at troja.net>
> Date: May 17, 2004 4:16:40 AM MST
> To: grass5 at grass.itc.it
> Subject: Re: [GRASS5] libz error compiling qgis
> Hi Michael
>> I am trying to compile QGIS on my Mac (OSX 10.3.3) to get some idea of
>> where GRASS is heading. There is no assurance that it will compile on
>> a
>> Mac OSX 10.3.3--but there is no indication yet that it won't.
> Latest CVS should work fine with Mac OSX, there were some changes to
> fix
> endian problems.
>> After a bit of futzing, my ./configure went well. But when I tried to
>> do a make, it died with the following error.
>> ld: /usr/local/pgsql/lib/libpq.a(fe-secure.o) illegal reference to
>> symbol: _SSL_connect defined in indirectly referenced dynamic library
>> /usr/lib/libssl.0.9.7.dylib
>> symbol: _BIO_free defined in indirectly referenced dynamic library
>> /usr/lib/libcrypto.0.9.7.dylib
>> ld: warning multiple definitions of symbol _adler32
>> /usr/lib/libz.1.1.3.dylib(adler32.o) definition of _adler32
>> /usr/lib/libz.dylib(adler32.o) definition of _adler32
>> ld: warning multiple definitions of symbol _crc32
>> /usr/lib/libz.1.1.3.dylib(crc32.o) definition of _crc32
>> /usr/lib/libz.dylib(crc32.o) definition of _crc32
>> ld: warning multiple definitions of symbol _get_crc_table
>> /usr/lib/libz.1.1.3.dylib(crc32.o) definition of _get_crc_table
>> /usr/lib/libz.dylib(crc32.o) definition of _get_crc_table
>> I have been able to find references to others having problems with
>> libz, but no one seems to indicate what program this library comes
>> with. I thought before bugging the qGIS people, I'd see if any of you
>> have some idea about this.
> I'm not sure about that, but perhaps /usr/lib/libz.dylib must be a
> link to
> /usr/lib/libz.1.1.3.dylib, when it's the same mechanism as on Linux.
> If you have questions about qgis, you can come to the #qgis channel on
> irc.freenode.net or join the ml.
> Ciao
> Jens Oberender
> Die Liebe ist ein seltsam Ding.
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20040518/d14208f0/attachment.bin
