[GRASS5] src/scripts compile error
Kirk R. Wythers
kwythers at umn.edu
Tue May 18 17:55:34 EDT 2004
gmake5 and gmake 53 are in my $PATH.
barbaloot:~ kirkw$ $PATH
bash:
/sw/bin:/sw/sbin:/usr/bin:/usr/local/bin:/bin:/usr/sbin:/sbin:/Users/
kirkw/bin:/usr/X11R6/bin:/opt/ibmcmp/vacpp/6.0/bin:/opt/ibmcmp/xlf/8.1/
bin: No such file or directory
barbaloot:~ kirkw$
barbaloot:~ kirkw$ which gmake53
/usr/local/bin/gmake53
Same goes for gmake5.
I only called it with the relative PATH in order to generate the error
message. Otherwise I only get the "Compilation error in module:" error:
GRASS GIS source code compiled.
Compilation error in module: src/scripts (ignored)
Compilation error in module: src/display/d.text.freetype (ignored)
Kirk
On May 18, 2004, at 4:32 PM, Glynn Clements wrote:
> Kirk R. Wythers wrote:
>> Still fighting with with compileing 53. Does anyone recognize this
>> one?:
>> truffula:~/grass5_dev/grass53_cvs_exp/src/scripts kirkw$
>> ../../bin.powerpc-apple-darwin7.3.0/gmake53
> Referring to gmake5, gmake53 etc using a relative path doesn't work.
> You either have to install it somewhere in $PATH, so that just typing
> "gmake53" works, or you have to use an absolute path, e.g.
> `pwd`/../../bin.powerpc-apple-darwin7.3.0/gmake53
> Glynn Clements <glynn.clements at virgin.net>
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
Kirk R. Wythers tel: 612.625.2261
Dept. of Forest Resources fax: 612.625.5212
University of Minnesota email: kwythers at umn.edu
