[GRASS5] re-make gmake53
Paul Kelly
paul-grass at stjohnspoint.co.uk
Thu May 20 14:27:18 EDT 2004
On Thu, 20 May 2004, Kirk R. Wythers wrote:
> I finally looked at /usr/local/bin/gmake53 and see that it is the cause of my
> troubles. It contains paths that no longer exist. For example:
> #!/bin/sh
> SRC=/Users/kirkw/grass5_dev/grass53_exp_2004_03_13/src
> CMD=/Users/kirkw/grass5_dev/grass53_exp_2004_03_13/src/CMD
> UNUSED=/Users/kirkw/grass5_dev/grass53_exp_2004_03_13/unused
> HEADER=head.powerpc-apple-darwin7.3.0
> HASX=yes
> HASMotif=no
> MAKE=make
> The build path is now truffula:~/grass5_dev/grass-5.3.0/
> I tried 'make distclean', but no go. What is thee command to re-create
> /usr/local/bin/gmake53?
Just use the gmake53 that is associated with the source distribution in
/Users/kirkw/grass5_dev/grass-5.3.0. It doesn't have to be in
/usr/local/bin
e.g. If you are using the conventional build mechanism it should be
/Users/kirkw/grass5_dev/grass-5.3.0/bin.powerpc-apple-darwin7.3.0/gmake53
(you need to use the full path)
