[GRASS5] GRASS <-> GDAL circular references
Glynn Clements
glynn.clements at virgin.net
Fri May 21 12:20:50 EDT 2004
Radim Blazek wrote:
> because of conflicts between GRASS and libgrass when used together
> (the same names of functions), I have tried to rewrite
> GRASS driver in GDAL to use GRASS 5.7 shared libs.
> I used GPJ_grass_to_wkt to get projection informations, unfortunately
> libgrass_gproj is linked to libgdal which makes circular reference.
> The same problem will be with potential GRASS vector driver in OGR.
> What is the correct solution?
Probably to remove the GDAL stuff from libgrass_gproj. 5.0/5.3 worked
OK without it.
Given the nature of GDAL (C++, many dependencies, possible dependency
upon GRASS), the less that depends upon it, the better.
Glynn Clements <glynn.clements at virgin.net>
