[GRASS5] GRASS <-> GDAL circular references
Radim Blazek blazek at itc.it
Fri May 21 07:31:41 EDT 2004
because of conflicts between GRASS and libgrass when used together
(the same names of functions), I have tried to rewrite
GRASS driver in GDAL to use GRASS 5.7 shared libs.
I used GPJ_grass_to_wkt to get projection informations, unfortunately
libgrass_gproj is linked to libgdal which makes circular reference.
The same problem will be with potential GRASS vector driver in OGR.
What is the correct solution?
Radim
