[GRASS5] [bug #2424] (grass) creating new location with grass57
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon May 24 05:10:05 EDT 2004
On Mon, 24 May 2004, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2424
> when creating a new location with grass 5.7 (i installed precompiled binaries
> 10.5.04) no location is created. the following is displayd in the command
> window when button 'create location from epsg' :
> g.proj: relocation error: /usr/local/grass57-10_05_2004/lib/libgrass_gproj.so:
> undefined symbol: OSRMorphFromESRI
It sounds like your GDAL isn't installed properly. Is it in a directory
included in LD_LIBRARY_PATH or /etc/ld.so.conf?
