[GRASS5] Re: GRASS <-> GDAL circular references
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed May 26 11:59:02 EDT 2004
Hello Radim
On Wed, 26 May 2004, Radim Blazek wrote:
> On Tuesday 25 May 2004 12:09, Paul Kelly wrote:
>>>> Should we add somehow --no-undefined to make sure that it compiles on
>>> Cygwin? It is not standard linker flag I guess. It is probably sufficient
>>> if developers set this flag?
>> As far as I know I don't think that is possible for Cygwin DLLs; the
>> dependencies on shared libraries have to be added to the linker
>> command-line and there seems to be no way to create DLLs with undefined
>> symbols. In 5.3 EXTRA_LIBS is called SLIBDEPS; it seems to be a fairly
>> standard thing and I think it is correct for it to be there?
> ld manpage:
> --no-undefined
> Normally when creating a non-symbolic shared library, undefined symbols are allowed and
> left to be resolved by the runtime loader. These options disallows such undefined symbols.
> I thought, that we could use it on Linux, to ensure that it cannot happen on Cygwin.
Ah, I think I see what you mean now. That sounds like a good idea. I
thought you were suggesting to remove EXTRA_LIBS and use --no-undefined,
which didn't seem to make sense to me because it meant it could never work
on Cygwin (i.e. without the EXTRA_LIBS line). Though maybe EXTRA_LIBS should
be renamed SLIBDEPS. The 5.7 build system really needs slightly updated to
use the aclocal.m4 from 5.3 and this could be done at the same time, but I
don't really see me having time to do this soon.
Paul
