[GRASS5] NVIZ and mkdsp
    Michael Barton
    michael.barton at asu.edu
    Fri May 28 14:20:44 EDT 2004
I tried NVIZ on the sample 3D weather data set to see how it displayed
(cvs version 2004-05-26). I first did an r3.info and it read the
provided cloud dataset correctly as far as I can tell.
I entered the name of the cloud dataset into the 'input file' box in
the mkdspf panel, gave an output name and pressed the 'accept' button.
It generated the following error. I tried to add some values for iso
levels, but it gave the same error. I tried a couple variations of the
file name and iso levels but they made no difference.
It could be my ignorance of how NVIZ works with g3d files, but could be
a real error. Does anyone have a suggestion? Thanks.
Michael Barton
- - - NVIZ error - - -
invalid command name
".top2.panelarea.panels.mkdspf.threshold.individual.list.l"
     while executing
"$BASE.threshold.individual.list.l size"
     ("individual" arm line 7)
     invoked from within
"switch $mkdspf_threshtype {
		complete {
			# First set the threshold type
			set thresh_type c
			# Now figure out the interval size to use
			set t..."
     (procedure "mkdspf_go" line 18)
     invoked from within
"mkdspf_go .top2.panelarea.panels.mkdspf"
     invoked from within
".top2.panelarea.panels.mkdspf.control.start invoke"
     ("uplevel" body line 1)
     invoked from within
"uplevel #0 [list $w invoke]"
     (procedure "tk::ButtonUp" line 22)
     invoked from within
"tk::ButtonUp .top2.panelarea.panels.mkdspf.control.start"
     (command bound to event)
____________________
C. Michael Barton, Professor
School of Human Origins, Cultures, & Societies
PO Box 872402
Arizona State University
Tempe, AZ  85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
