[GRASS5] ERROR: MAPSET fakestart not found
Huidae Cho grass4u at gmail.com
Wed Nov 3 02:26:05 EST 2004
I got the following error when making r.digit:
GRASS_FAKE_START=1 GISBASE=... dist.i686-pc-cygwin/bin/r.digit
--html-description
ERROR: MAPSET fakestart not found.
r.digit does not call G_parser(), so it cannot generate usage. But it
fails with "Programmer error: no flags or options" error after
inserting G_parser() to make a usage file. "No flags or options" can
be intended by programmers, should it be something like fatal errors?
Thanks,
Huidae Cho
