[GRASS5] g.rename/g.copy vect
Radim Blazek blazek at itc.it
Wed Nov 3 11:30:35 EST 2004
I have added vect to g.rename and changed g.copy so that it should  be
faster with vectors  (using cp).
If input vector is OGR format , the output will be also OGR. Dead lines
are left in 'coor' for native
format. Please test carefully!
Radim
