[GRASS5] ERROR: MAPSET fakestart not found
Glynn Clements
glynn at gclements.plus.com
Wed Nov 3 23:54:56 EST 2004
Huidae Cho wrote:
> > > r.digit does not call G_parser(), so it cannot generate usage. But it
> > > fails with "Programmer error: no flags or options" error after
> > > inserting G_parser() to make a usage file. "No flags or options" can
> > > be intended by programmers, should it be something like fatal errors?
> > You mean above problem? No, that should not stop compilation.
> I mean "do we need the 'Programmer error: no flags or options' error?"
> If no options or flags are defined, it is intended by developers, so
> the module should continue instead of exit even if G_parser() is
> called to generate usage..
Agreed.
