[GRASS5] v.out.ascii / v.in.ascii
    Hamish
    hamish_nospam at yahoo.com
    Fri Nov  5 04:25:23 EST 2004
after running the latest v.in.ascii on a "new" style vector ascii file:
VERTI:
L 2 1
 x1 y1
 x2 y2
 1 1
etc.
I get the following [v.in.garmin]:
Importing with v.in.ascii
Building topology ...
1 primitives registered
0 areas built      0%
0 isles built
Topology was built.
Number of nodes     :   2
Number of primitives:   1
Number of points    :   0
Number of lines     :   1
Number of boundaries:   0
Number of centroids :   0
Number of areas     :   0
Number of isles     :   0
v.in.garmin: line vector "test5novRTE at mapset" successfully created
but when I do 'v.info test5novRTE', I get:
ERROR: Cannot open old vector test5novRTE at mapset on level 2
?, thanks
Hamish
