[GRASS5] v.out.ascii / v.in.ascii
Radim Blazek
blazek at itc.it
Fri Nov 5 04:39:40 EST 2004
Try the same directly with v.in.ascii.
What files are in vectors directory.
Does it help to run v.build?
Radim
Hamish wrote:
>after running the latest v.in.ascii on a "new" style vector ascii file:
>VERTI:
>L 2 1
> x1 y1
> x2 y2
> 1 1
>etc.
>I get the following [v.in.garmin]:
>Importing with v.in.ascii
>Building topology ...
>1 primitives registered
>0 areas built 0%
>0 isles built
>Topology was built.
>Number of nodes : 2
>Number of primitives: 1
>Number of points : 0
>Number of lines : 1
>Number of boundaries: 0
>Number of centroids : 0
>Number of areas : 0
>Number of isles : 0
>v.in.garmin: line vector "test5novRTE at mapset" successfully created
>but when I do 'v.info test5novRTE', I get:
>ERROR: Cannot open old vector test5novRTE at mapset on level 2
>?, thanks
>Hamish
