[GRASS5] v.out.ascii / v.in.ascii
Sun Nov 7 20:35:42 EST 2004
Hamish:
> >after running the latest v.in.ascii on a "new" style vector ascii file:
> >VERTI:
> >L 2 1
> > x1 y1
> > x2 y2
> > 1 1
> >etc.
> >I get the following [v.in.garmin]:
> >Importing with v.in.ascii
> >Building topology ...
> >1 primitives registered
> >0 areas built      0%
> >0 isles built
> >Topology was built.
> >Number of nodes     :   2
> >Number of primitives:   1
> >Number of points    :   0
> >Number of lines     :   1
> >Number of boundaries:   0
> >Number of centroids :   0
> >Number of areas     :   0
> >Number of isles     :   0
> >v.in.garmin: line vector "test5novRTE at mapset" successfully created
> >but when I do 'v.info test5novRTE', I get:
> >ERROR: Cannot open old vector test5novRTE at mapset on level 2
Radim:
> Try the same directly with v.in.ascii.
Same result. (sample file & DEBUG=5 stderr log attached; stdout is as above)
also
G57> d.vect test8novTRK
WARNING: Cannot display areas, topology not available
[input file (eg attached) only contains lines, they draw ok]
> What files are in vectors directory.
$ ls vector/test8novTRK/
coor  dbln  head  hist
> Does it help to run v.build?
Yes. After running v.build everything works as expected.
[not attached file..]
G57> v.build test8novTRK
152 primitives registered
0 areas built      8%
0 isles built
Topology was built.
Number of nodes     :   240
Number of primitives:   152
Number of lines     :   152
Number of areas     :   0
Number of isles     :   0
[0 areas built      8%] ????
Then these files exist:
G57>  ls vector/test8novTRK/
cidx  coor  dbln  head  hist  sidx  topo
thanks, I think v.in|out.ascii modes are much less confusing now.
Hamish
Type: application/octet-stream
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041108/75eb8777/7169.0.obj
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041108/75eb8777/vinascii.obj
