[GRASS5] CVS downtime for file copy
Radim Blazek
blazek at itc.it
Fri Nov 5 08:41:30 EST 2004
Bernhard Reiter wrote:
> Markus and Radim have send me a script for
> moving the files in CVS from grass5 to grass51.
> I plan to do the move tomorrow during the day.
> For the operation I will switch off CVS access
> for approximately 30 minutes.
> So watch this mailinglist, because if you are working on grass51,
> because you want to update your repositories after the move.
> Afterwards the list of files can be used to use cvs admin command
> to set a state or so, if you want to mark it.
It would be good to add a new log message for each file telling where it
comes from. I don't see however any cvs command which can add a log
message without changes in code. cvs admin can only change existing message.
Radim
