[GRASS5] CVS downtime for file copy
Bernhard Reiter
bernhard at intevation.de
Fri Nov 5 04:23:37 EST 2004
Markus and Radim have send me a script for
moving the files in CVS from grass5 to grass51.
I plan to do the move tomorrow during the day.
For the operation I will switch off CVS access
for approximately 30 minutes.
So watch this mailinglist, because if you are working on grass51,
because you want to update your repositories after the move.
Afterwards the list of files can be used to use cvs admin command
to set a state or so, if you want to mark it.
On Sat, Oct 02, 2004 at 05:00:24PM +0200, Bernhard Reiter wrote:
> We have no schedule yet.
> I cannot judge how complicated the current copying
> or mix linking is and how many changes are going to be made
> to the files. So the timing must be up for somebody else to decide.
> On Fri, Oct 01, 2004 at 04:00:43PM +0200, Radim Blazek wrote:
> > On Friday 01 October 2004 15:25, Bernhard Reiter wrote:
> > > > > I can move files or directories around in CVS in principle.
> > > > > Just need a good list.
> > > > > (probably the right mv commands might be most instructive ;) )
> > > > > and then I need to schedule shutting down CVS
> > > > > and doing the change.
> > > > > (Depending on my time this might a few days, so giving me an ahead
> > > > > notice is appreceated.)
> > > I would appreciate if someone would make a fixed list of "cp"
> > > command lines that I only need to source with the ",v" extension,
> > > because that seems more transparent as a script.
> > > Especially must there be checking if there is a corresponding file already?
> > > During a copy operation in the repository someone cannot put in CVS
> > > comments, they would be exactly the same as in the original file.
> > > Probably with cvs admin you can change something.
> > > Maybe basiing revision numbers starting with "2.x" ?
> > > When do you want this to happen?
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20041105/b6add401/attachment.bin
