[GRASS5] v.out.ascii / v.in.ascii
Radim Blazek blazek at itc.it
Fri Nov 5 10:39:48 EST 2004
Michael Barton wrote:
> This sounds like it makes the v.in.asciipoints script I wrote for GRASS 5.7
> obsolete. Is that correct? (It allowed a user to select an ascii file for
> input into v.in.ascii rather than making them do a "cat <file> |" from the
> command line).
Yes.
Radim
> Michael
> On 11/4/04 10:52 AM, "Radim Blazek" <blazek at itc.it> wrote:
>>WARNING: v.in.ascii and v.out.ascii were changed:
>>1) New option 'format' specifies if ascii file is 'standard' or 'point'.
>>2) The modules can read/write both format form file (input=path to file)
>>or stdin/stdout.
>>3) coordinates order was changed to X Y [Z] except 'v.out.ascii -o' for
>>standard format.
>>4) 'v.out.ascii -o' writes to dig_ascii/
>>Radim
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human, Evolution and Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
