[GRASS5] v.out.ascii / v.in.ascii
Michael Barton
michael.barton at asu.edu
Fri Nov 5 10:16:36 EST 2004
This sounds like it makes the v.in.asciipoints script I wrote for GRASS 5.7
obsolete. Is that correct? (It allowed a user to select an ascii file for
input into v.in.ascii rather than making them do a "cat <file> |" from the
command line).
Michael
On 11/4/04 10:52 AM, "Radim Blazek" <blazek at itc.it> wrote:
> WARNING: v.in.ascii and v.out.ascii were changed:
> 1) New option 'format' specifies if ascii file is 'standard' or 'point'.
> 2) The modules can read/write both format form file (input=path to file)
> or stdin/stdout.
> 3) coordinates order was changed to X Y [Z] except 'v.out.ascii -o' for
> standard format.
> 4) 'v.out.ascii -o' writes to dig_ascii/
> Radim
______________________________
Michael Barton, Professor of Anthropology
School of Human, Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
