WARNING: v.in.ascii and v.out.ascii were changed: 1) New option 'format' specifies if ascii file is 'standard' or 'point'. 2) The modules can read/write both format form file (input=path to file) or stdin/stdout. 3) coordinates order was changed to X Y [Z] except 'v.out.ascii -o' for standard format. 4) 'v.out.ascii -o' writes to dig_ascii/ Radim
