[GRASS5] Re: nviz segfault with grass5.7.0
Stefan Paulick
stefan.paulick at urbeli.com
Sun Nov 7 13:11:06 EST 2004
You may try to build all the packages out of sources / CVS; in particular
when using a 64bit platform.
Mit freundlichen Grüßen / With kindest regards
Stefan Paulick
http://www.urbeli.com
mailto://stefan.paulick@urbeli.com
Soeren Gebbert schrieb:
> Dear developers,
> I have used the gdb and now i'm more confused than befor:
> I tried to visualize this map:
> | Type of Map: raster Number of Categories: 255
> | Data Type: FCELL
> | Rows: 1579
> | Columns: 2257
> | Total Cells: 3563803
> | Projection: UTM (zone 29)
> | N: 4121508.96 S: 4118161.48 Res: 2.12
> | E: 558204.48 W: 553419.64 Res: 2.12
> | Range of data: min = 13.817110 max = 196.461456
> | Data Source:
> | vector file Elevation
> I get this error:
> Program received signal SIGSEGV, Segmentation fault.
> [Switching to Thread 182923337952 (LWP 17399)]
> 0x0000002a96640f33 in G_zero_raster_buf (rast=0xffffffff99a3f010,
> data_type=4) at zero_cell.c:34
> 34 *ptr++ = 0 ;
> The G_window_cols() routine in G_zero_raster_buf() says, the window has
> 2269 cols, so it is bigger than the map.
> Ok, i zoomed in and now i get this error:
> [Switching to Thread 182923337952 (LWP 17418)]
> 0x0000003ed19debd6 in xdr_float () from /lib64/tls/libc.so.6
> Does someone has a hint?
> Best regards
> Sören
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
