[GRASS5] problem compiling 57
ivan marchesini marchesini at unipg.it
Tue Nov 9 13:49:00 EST 2004
sorry markus, sorry all...
another thing.....
I'm using tcl/tk8.4
can be a problem???
because it seems to me to have read something bad about tcltk8.4 and
grass57.....
thank you very much....
bye
ivan
Il mar, 2004-11-09 alle 18:20, Markus Neteler ha scritto:
> On Tue, Nov 09, 2004 at 03:41:15PM +0100, ivan marchesini wrote:
> > Dear all/developers,
> > I have just downloaded grass5.7.0 source code (not CVS)...
> > the ./configure was good....
> > later, I tried the make command and I obtained an error....
> > I have put here the last rows of the compilation process:
> > ____________________________________________________________
> > -lGL  -ltiff -lm -lgrass_image -lgrass_si
> > tes  -o
> > /home/simona/Documents/GRASS/grass-5.7.0/dist.i686-pc-linux-gnu/lib/lib                               grass_ogsf.so
> > /usr/bin/ld: cannot find -lGL
> > collect2: ld returned 1 exit status
> > make[2]: ***
> > [/home/simona/Documents/GRASS/grass-5.7.0/dist.i686-pc-linux-gnu/l                               ib/libgrass_ogsf.so] Error 1
> > make[2]: Leaving directory
> > `/home/simona/Documents/GRASS/grass-5.7.0/lib/ogsf'
> > make[1]: *** [subdirs] Error 1
> > make[1]: Leaving directory
> > `/home/simona/Documents/GRASS/grass-5.7.0/lib'
> > make: *** [default] Error 1
> > can you give me some helps....
> > thank you
> It doesn't find libGL.so... Maybe no openGL present in your system?
> Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
