[GRASS5] problem compiling 57
Markus Neteler neteler at itc.it
Tue Nov 9 12:20:37 EST 2004
On Tue, Nov 09, 2004 at 03:41:15PM +0100, ivan marchesini wrote:
> Dear all/developers,
> I have just downloaded grass5.7.0 source code (not CVS)...
> the ./configure was good....
> later, I tried the make command and I obtained an error....
> I have put here the last rows of the compilation process:
> ____________________________________________________________
> -lGL  -ltiff -lm -lgrass_image -lgrass_si
> tes  -o
> /home/simona/Documents/GRASS/grass-5.7.0/dist.i686-pc-linux-gnu/lib/lib                               grass_ogsf.so
> /usr/bin/ld: cannot find -lGL
> collect2: ld returned 1 exit status
> make[2]: ***
> [/home/simona/Documents/GRASS/grass-5.7.0/dist.i686-pc-linux-gnu/l                               ib/libgrass_ogsf.so] Error 1
> make[2]: Leaving directory
> `/home/simona/Documents/GRASS/grass-5.7.0/lib/ogsf'
> make[1]: *** [subdirs] Error 1
> make[1]: Leaving directory
> `/home/simona/Documents/GRASS/grass-5.7.0/lib'
> make: *** [default] Error 1
> can you give me some helps....
> thank you
It doesn't find libGL.so... Maybe no openGL present in your system?
Markus
