[GRASS5] problem compiling 57: SOLVED
ivan marchesini
marchesini at unipg.it
Thu Nov 11 06:03:12 EST 2004
Thanks to all....
the problem was the freetype support....
adding freetype 2 all is working really well....
thank you very much!!!!
ivan
Il mar, 2004-11-09 alle 17:12, glynn at gclements.plus.com ha scritto:
> ivan marchesini wrote:
> > Dear all/developers,
> > I have just downloaded grass5.7.0 source code (not CVS)...
> > the ./configure was good....
> > later, I tried the make command and I obtained an error....
> > I have put here the last rows of the compilation process:
> > /home/simona/Documents/GRASS/grass-5.7.0/dist.i686-pc-linux-gnu/lib/libgrass_ogsf.so
> > /usr/bin/ld: cannot find -lGL
> The OGSF library requires OpenGL. However, it is built regardless of
> whether you use --with-opengl.
> Also, 5.7.0 aborts on the first error, while later CVS versions will
> move on to the next module.
