[GRASS5] problem compiling 57
ivan marchesini
marchesini at unipg.it
Tue Nov 9 13:52:23 EST 2004
Dear Marcus...., dear all
I have done what you said...
I entered the grass source cvs location....
I did
__________
cvs up -dP
__________
then configure:
__________________________________________________________________
CFLAGS="-g -Wall" ./configure
--with-grass50=/home/simona/Documents/GRASS/grass53_exp_2004_11_06/
--with-tcltk-includes=/usr/include/ --with-postgres=no
--with-opengl-includes=/usr/X11R6/include/GL/ --without-odbc
--without-fftw --with-proj=yes
(is correct??? because I'm not sure to have understood you previous
e-mail.... I still need the 53cvs source code to compile CVS, it's
only not necessary to compile 53.....)
then
______
make
________
and the error.log is this:
GRASS GIS compilation log
Started compilation: mar nov 9 19:10:18 CET 2004
Errors in:
/home/simona/Documents/GRASS/grass57_exp_2004_11_06/display/drivers/XDRIVER/XDRIVER24
/home/simona/Documents/GRASS/grass57_exp_2004_11_06/display/drivers/PNG
/home/simona/Documents/GRASS/grass57_exp_2004_11_06/raster3d/r3.showdspf
Finished compilation: mar nov 9 19:28:03 CET 2004
there is the error on the XDRIVER24.....
I have made some errors during the CVS update??????????
thank you very much....
Il mar, 2004-11-09 alle 18:59, Markus Neteler ha scritto:
> On Tue, Nov 09, 2004 at 06:54:17PM +0100, ivan marchesini wrote:
> > Dear Marcus, dear all....
> > after the ./configure process I obtained the make script opengl
> > configured...... so I'm sure to have the opengl....
> so configure states that OpenGL is there?
> Good.
> > anyway....I have another problem:
> > later I decided to try with CVS ....
> > I have compiled 53CVS correctly and then I started to compile 57CVS with
> The *compilation* if 5.3 is not required.
> >From today CVS onwards not even the 5.3 source code is any more required.
> > all works well....
> > and at the end I obtained the grass57 compiled....
> > the problem is that I'm not able to start
> > monitors....!!!!!!!!!!!!!!!!!!!!
> Don't panic :-)
> > after d.mon start=x0 I obtain this:
> > Could not execute monitor: No such file or directory
> > No socket to connect to for monitor <x1>.
> > Problem selecting x1. Will try once more
> Yes, it was simply not compiled.
> > going into details:
> The details we need here are the contents
> of the error.log which is displayed after compilation.
> If there is an error, it should be fixed first.
> How to find out:
> - go into the directory where the error occured
> - run 'make' there
> - analyse and/or send the error message
> Please, before trying, update from CVS as I have fixed
> a bug in the XDRIVER (see mailing list).
> #in grass57 main source dir
> cvs up -dP
> #Watch out for problems as usual.
> #then
> make
> #then
> check what error.log tells you.
> > I have compiled using this configure script:
> > ____________________________________________________________________
> this is no longer needed if you have a recent (todays) CVS version.
> See mailing list discussion.
> > help me please.......
> > I have had an hard day... :-)
> me too :-)
> hope this helps
> markus
