[GRASS5] problem compiling 57
Markus Neteler
neteler at itc.it
Wed Nov 10 02:23:44 EST 2004
Ciao Ivan,
tcl/tk8.4 works well (probably only on non-Debian systems?).
At least with Mdk10.0.
On Tue, Nov 09, 2004 at 07:52:23PM +0100, ivan marchesini wrote:
> Dear Marcus...., dear all
> I have done what you said...
> I entered the grass source cvs location....
> I did
> __________
> cvs up -dP
ok
> then configure:
> __________________________________________________________________
> CFLAGS="-g -Wall" ./configure
> --with-grass50=/home/simona/Documents/GRASS/grass53_exp_2004_11_06/
> --with-tcltk-includes=/usr/include/ --with-postgres=no
> --with-opengl-includes=/usr/X11R6/include/GL/ --without-odbc
> --without-fftw --with-proj=yes
> (is correct??? because I'm not sure to have understood you previous
> e-mail.... I still need the 53cvs source code to compile CVS, it's
> only not necessary to compile 53.....)
- it was never required to compile G5.3
- since yesterday: not even the source code of 5.3 is required any more
(in italiano: non ti serve piu' il codice sorgente di 5.3; basta
il codice di 5.7)
Additionally, please add above
--with-freetype --with-freetype-includes=/usr/include/freetype2
So completely:
CFLAGS="-g -Wall" ./configure \
--with-postgres=no \
--with-opengl-includes=/usr/X11R6/include/GL \
--without-odbc \
--without-fftw \
> then
> ______
> make
> ________
> and the error.log is this:
> GRASS GIS compilation log
> Started compilation: mar nov 9 19:10:18 CET 2004
> Errors in:
> /home/simona/Documents/GRASS/grass57_exp_2004_11_06/display/drivers/XDRIVER/XDRIVER24
> /home/simona/Documents/GRASS/grass57_exp_2004_11_06/display/drivers/PNG
> /home/simona/Documents/GRASS/grass57_exp_2004_11_06/raster3d/r3.showdspf
> Finished compilation: mar nov 9 19:28:03 CET 2004
> there is the error on the XDRIVER24.....
> I have made some errors during the CVS update??????????
No. But the currently required Freetype2 was not defined above.
Please add it to compile the XDRIVER.
hope this helps
Markus
> Il mar, 2004-11-09 alle 18:59, Markus Neteler ha scritto:
> > On Tue, Nov 09, 2004 at 06:54:17PM +0100, ivan marchesini wrote:
> > > Dear Marcus, dear all....
> > > after the ./configure process I obtained the make script opengl
> > > configured...... so I'm sure to have the opengl....
> > so configure states that OpenGL is there?
> > Good.
> > > anyway....I have another problem:
> > > later I decided to try with CVS ....
> > > I have compiled 53CVS correctly and then I started to compile 57CVS with
> > The *compilation* if 5.3 is not required.
> > >From today CVS onwards not even the 5.3 source code is any more required.
> > > all works well....
> > > and at the end I obtained the grass57 compiled....
> > > the problem is that I'm not able to start
> > > monitors....!!!!!!!!!!!!!!!!!!!!
> > Don't panic :-)
> > > after d.mon start=x0 I obtain this:
> > > Could not execute monitor: No such file or directory
> > > No socket to connect to for monitor <x1>.
> > > Problem selecting x1. Will try once more
> > Yes, it was simply not compiled.
> > > going into details:
> > The details we need here are the contents
> > of the error.log which is displayed after compilation.
> > If there is an error, it should be fixed first.
> > How to find out:
> > - go into the directory where the error occured
> > - run 'make' there
> > - analyse and/or send the error message
> > Please, before trying, update from CVS as I have fixed
> > a bug in the XDRIVER (see mailing list).
> > #in grass57 main source dir
> > cvs up -dP
> > #Watch out for problems as usual.
> > #then
> > make
> > #then
> > check what error.log tells you.
> > > I have compiled using this configure script:
> > > ____________________________________________________________________
> > this is no longer needed if you have a recent (todays) CVS version.
> > See mailing list discussion.
> > > help me please.......
> > > I have had an hard day... :-)
> > me too :-)
> > hope this helps
> > markus
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
