[GRASS5] problem compiling 57
Kirk R. Wythers
kwythers at umn.edu
Wed Nov 10 09:30:40 EST 2004
On Nov 10, 2004, at 1:23 AM, Markus Neteler wrote:
> - since yesterday: not even the source code of 5.3 is required any more
> (in italiano: non ti serve piu' il codice sorgente di 5.3; basta
> il codice di 5.7)
Is this true? If I compile the new 51 branch without shared, there are
there are a number of general commands that are missing (and they
happen to be the same ones that give bus errors when I try and run
them.
For example in:
\barbaloot:~/grass5_dev/grass51/general kirkw$ ls
CVS/ g.filename/ g.mapsets/ g.setproj/ manage/
Makefile g.findfile/ g.parser/ g.tempfile/
g.access/ g.gisenv/ g.proj/ g.version/
g.ask/ g.mapset/ g.region/ g3.region/
I don't see g.copy, g.list, g.remove, g.region, or g.mremove. Am I
missing something here (either figuratively or literally).
Kirk R. Wythers
Dept. of Forest Resources
University of Minnesota
email: kwythers at umn.edu
tel: 612.625.2261
fax: 612.625.5212
