[GRASS5] problem compiling 57
Glynn Clements
glynn at gclements.plus.com
Wed Nov 10 11:48:00 EST 2004
Kirk R. Wythers wrote:
> > - since yesterday: not even the source code of 5.3 is required any more
> > (in italiano: non ti serve piu' il codice sorgente di 5.3; basta
> > il codice di 5.7)
> Is this true? If I compile the new 51 branch without shared, there are
> there are a number of general commands that are missing (and they
> happen to be the same ones that give bus errors when I try and run
> them.
> For example in:
> \barbaloot:~/grass5_dev/grass51/general kirkw$ ls
> CVS/ g.filename/ g.mapsets/ g.setproj/ manage/
> Makefile g.findfile/ g.parser/ g.tempfile/
> g.access/ g.gisenv/ g.proj/ g.version/
> g.ask/ g.mapset/ g.region/ g3.region/
> I don't see g.copy, g.list, g.remove, g.region, or g.mremove. Am I
> missing something here (either figuratively or literally).
All of those are in the "manage" subdirectory, except for g.mremove,
which is a script (as is g.mlist). That is true for both 5.3 and 5.7.
