[GRASS5] problem compiling 57
Markus Neteler neteler at itc.it
Wed Nov 10 11:49:23 EST 2004
On Wed, Nov 10, 2004 at 08:30:40AM -0600, Kirk R. Wythers wrote:
> On Nov 10, 2004, at 1:23 AM, Markus Neteler wrote:
> >- since yesterday: not even the source code of 5.3 is required any more
> >  (in italiano: non ti serve piu' il codice sorgente di 5.3; basta
> >   il codice di 5.7)
> Is this true? If I compile the new 51 branch without shared, there are
> there are a number of general commands that are missing (and they
> happen to be the same ones that give bus errors when I try and run
> them.
> For example in:
> \barbaloot:~/grass5_dev/grass51/general kirkw$ ls
> CVS/            g.filename/     g.mapsets/      g.setproj/      manage/
> Makefile        g.findfile/     g.parser/       g.tempfile/
> g.access/       g.gisenv/       g.proj/         g.version/
> g.ask/          g.mapset/       g.region/       g3.region/
> I don't see g.copy, g.list, g.remove, g.region, or g.mremove. Am I
> missing something here (either figuratively or literally).
Looks like a local compilation problem or MacOSX problem.
Just watch out for compilation errors.
In my Linux box I have:
GRASS 5.7.cvs:~ > g.
g.access                 g.findfile               g.mapsets                g.region
g.apropos                g.gisenv                 g.mlist                  g.remove
g.ask                    g.link                   g.mremove                g.rename
g.copy                   g.list                   g.out.prj                g.setproj
                         g.manual                 g.parser                 g.tempfile
g.filename               g.mapset                 g.proj                   g.version
All common stuff is of course there.
Markus
