[GRASS5] problem compiling 57
Hamish
hamish_nospam at yahoo.com
Wed Nov 10 18:25:06 EST 2004
> Is this true? If I compile the new 51 branch without shared, there are
> there are a number of general commands that are missing
Really missing or apparently missing? Look in "error.log" for modules which
did not compile.
> For example in:
> \barbaloot:~/grass5_dev/grass51/general kirkw$ ls
> CVS/ g.filename/ g.mapsets/ g.setproj/ manage/
> Makefile g.findfile/ g.parser/ g.tempfile/
> g.access/ g.gisenv/ g.proj/ g.version/
> g.ask/ g.mapset/ g.region/ g3.region/
> I don't see g.copy, g.list, g.remove, g.region, or g.mremove. Am I
> missing something here (either figuratively or literally).
(they are in manage/)
> (and they happen to be the same ones that give bus errors when I try and
> run them.
There was this change last week,
http://freegis.org/cgi-bin/viewcvs.cgi/grass51/general/manage/lib/do_rename.c.diff?r1=1.2&r2=1.3
but that shouldn't affect all the modules.
Hamish
