[GRASS5] Fwd: [winGRASS] db driver problem?
Huidae Cho
grass4u at gmail.com
Wed Nov 10 23:30:01 EST 2004
Yes, you're right.
I spent some time to figure out how this can be solved and found that
I cannot use different function names for stub things because
libgrass_dbmidriver.dll cannot be built with undefined functions
(sould be defined either in the dbstub library or in real drivers).
So I tested some tricky way with success and changed db drivers,
please test new implementation.
Affected directories:
grass51/lib/db/stubs
grass51/lib/db/dbmi_driver
grass51/db/drivers
Thank you.
Huidae Cho
On Wed, 10 Nov 2004 17:36:11 +0000, Glynn Clements
<glynn at gclements.plus.com> wrote:
> Huidae Cho wrote:
> > Is no body interested in this issue just because the number of
> > winGRASS users is small? :-)
> More accurately, because the number of winGRASS *developers* is small.
> AFAICT, most of the winGRASS users aren't developers, and most of the
> GRASS developers don't use Windows.
> Glynn Clements <glynn at gclements.plus.com>
