> So I tested some tricky way with success and changed db drivers, > please test new implementation. > > Affected directories: > grass51/lib/db/stubs > grass51/lib/db/dbmi_driver > grass51/db/drivers be sure to update the Doxygen comments while you're at it..... Hamish
