[GRASS5] Fwd: [winGRASS] db driver problem?
Hamish
hamish_nospam at yahoo.com
Thu Nov 11 00:31:20 EST 2004
On Wed, 10 Nov 2004 23:04:38 -0600
Huidae Cho <grass4u at gmail.com> wrote:
> On Thu, 11 Nov 2004 17:52:43 +1300, Hamish <hamish_nospam at yahoo.com> wrote:
> > > So I tested some tricky way with success and changed db drivers,
> > > please test new implementation.
> > > Affected directories:
> > > grass51/lib/db/stubs
> > > grass51/lib/db/dbmi_driver
> > > grass51/db/drivers
> > be sure to update the Doxygen comments while you're at it.....
> Sorry for my ignorance. Which file do you mean?
e.g.:
http://freegis.org/cgi-bin/viewcvs.cgi/grass51/lib/db/stubs/add_col.c?rev=2.1&content-type=text/vnd.viewcvs-markup
comments get turned into the Programmer's manual, so if the function name
changes the comment should as well.
Hamish
(leave in the _nospam)
