[GRASS5] [bug #2689] (grass) i.vpoints misc minor problems
Request Tracker
grass-bugs at intevation.de
Sat Nov 13 04:43:41 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2689
Subject: i.vpoints misc minor problems
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: 5.7cvs_1nov2004
some i.vpoints problems:
bug:
when the monitor is too narrow you can't select input method: [keyboard or screen] (window needed to be ~ 900 pixels wide to select keyboard)
bug:
I also managed to hard-lock the program somehow.
(needed 'pkill -9 i.vpoints' and xkill the x0 window)
Not quite sure exactly how.
bug:
can't unzoom vector map beyond WIND in target mapset
bug:
can't backspace during keyboard input of GCPs.
bug:
analyze window columns are too crowded and overlap
bug:
doesn't use DEFAULT_BG_COLOR for background, possible consequence of this is green button commands' edges at bottom hard to distinguish from each other.
This looks nice in i.points.
wish:
add support for lat/lon ddd:mm:ss keyboard input like v.points has.
[done; currently have to explicity label east "E" (eg 123:55E 45:30S)]
see also bug # 1077
http://intevation.de/rt/webrt?serial_num=1077
Hamish
-------------------------------------------- Managed by Request Tracker
