'field' option is used as layer identifier in 5.7. Each vector can contain more layers, for example field=1 : forests field=2 : lakes Unfortunately the name 'field' is commonly used for table columns, so it is quite confusing. My suggestion is to use option key 'layer' instead of 'field'. Radim
