[GRASS5] tcltkgrass - some bugs remain
Maciek Sieczka
werchowyna at pf.pl
Sun Nov 14 10:35:00 EST 2004
Hi
Following bugs still remain in the tcltkgrass 5.3 CVS 2004_11_06. I only
checked those I had problems with in the past. Some of them were
already once reported. I wonder if there are more. In the 5.4 "release"
too?
v.out.shape
Sorry, <output> is not a valid parameter
Sorry <0> is not a valid option
Raster -> Generate surfaces -> Generate fractal surfaces still leads to
r.surf.area instead of r.surf.fractal which results in:
Sorry, <out> is not a valid parameter
Sorry, <d> is not a valid parameter
ERROR: Required parameter <input> not set:
(Raster file for surface.).
s.surf.rst:
1 missing entries for output files: treefile, overfile, devi
2 the default "Minimum number of points for interpolation: 200" - should
be 300
3 still interactive like this after which it stops:
WARNING: old data format detected.
Convert site file to new format?
Answering yes will modify your site list file.(y/n) [y]
d.3d:
after pressing the "xyz" button an information window pops up with a
bunch of "%\b\b\b\b"
no entry for r.bilinear
r.out.hdf, v.ascii.spag:
"no such file or directory" - are these entries necesssary?
v.in.dxf3d.sh
Unrecognized option: lines=elevs
Options: dxf=name line1=name line2=name
Config -> Set fonts -> Module font
bad window path name ".s_proj"
while executing
"winfo children $path"
(procedure "children" line 3)
invoked from within
"children $path"
(procedure "setfont" line 3)
invoked from within
"setfont .$module $module_font"
("foreach" body line 1)
invoked from within
"foreach module $module_list {setfont .$module $module_font} "
invoked from within
".main_menu.mb9.m.m2 invoke active"
("uplevel" body line 1)
invoked from within
"uplevel #0 [list $w invoke active]"
(procedure "tk::MenuInvoke" line 47)
invoked from within
"tk::MenuInvoke .main_menu.mb9.m.m2 1"
(command bound to event)
