[GRASS5] tcltkgrass - some bugs remain
Glynn Clements
glynn at gclements.plus.com
Sun Nov 14 11:14:25 EST 2004
Maciek Sieczka wrote:
> Following bugs still remain in the tcltkgrass 5.3 CVS 2004_11_06. I only
> checked those I had problems with in the past. Some of them were
> already once reported. I wonder if there are more. In the 5.4 "release"
> too?
> v.out.shape
> Sorry, <output> is not a valid parameter
> Sorry <0> is not a valid option
> Raster -> Generate surfaces -> Generate fractal surfaces still leads to
> r.surf.area instead of r.surf.fractal which results in:
> Sorry, <out> is not a valid parameter
> Sorry, <d> is not a valid parameter
> ERROR: Required parameter <input> not set:
> (Raster file for surface.).
> s.surf.rst:
> 1 missing entries for output files: treefile, overfile, devi
> 2 the default "Minimum number of points for interpolation: 200" - should
> be 300
> 3 still interactive like this after which it stops:
> WARNING: old data format detected.
> Convert site file to new format?
> Answering yes will modify your site list file.(y/n) [y]
I've commited fixes for these three.
> v.in.dxf3d.sh
> Unrecognized option: lines=elevs
> Options: dxf=name line1=name line2=name
The module file is correct for v.in.dxf3d; I'm not sure whether the
module should be running v.in.dxf3d instead of v.in.dxf3d.sh, or
whether the syntax should be changed to match v.in.dxf3d.sh.
