[GRASS5] tcltkgrass - some bugs remain
Markus Neteler
neteler at itc.it
Mon Nov 15 08:06:34 EST 2004
On Sun, Nov 14, 2004 at 04:14:25PM +0000, Glynn Clements wrote:
> > v.in.dxf3d.sh
> > Unrecognized option: lines=elevs
> > Options: dxf=name line1=name line2=name
> The module file is correct for v.in.dxf3d; I'm not sure whether the
> module should be running v.in.dxf3d instead of v.in.dxf3d.sh, or
> whether the syntax should be changed to match v.in.dxf3d.sh.
Here a try for an overview:
- v.in.dxf: Converts files in DXF format to ASCII or binary GRASS vector file
format.
- v.in.dxf3d: Converts the Z values of DXF files to attribute GRASS vector file
format.
- v.in.dxf3d.sh: Imports 3D contour lines from DXF3D file using v.in.dxf and
v.in.dxf3d
- v.cadlabel: Attaches labels to (binary) vector contour lines that have been
imported to GRASS from DXF format.
Markus
