[GRASS5] [bug #2690] (grass) System Response when no colortable is present
Request Tracker
grass-bugs at intevation.de
Mon Nov 15 03:05:35 EST 2004
this bug's URL: http://intevation.de/rt/webrt?serial_num=2690
Subject: System Response when no colortable is present
Platform: GNU/Linux/i386
grass obtained from: CVS
grass binary for platform: Compiled from Sources
GRASS Version: CVS
Dear developers,
not really a bug, but a proposal for a message when importing Raster-maps without colortables. The Problem appears when importing a rastermap without a proper colortable. When trying to display this map, nothing appears on the screen even when setting the region to the imported map. The system should then give a message, that no appropriate colortable is present and give a hint to using r.colors. Especially for new users it might be a great help so that they can be sure, no errors occured during import and they additionally should set a colortable.
Cheers
Stephan Holl
-------------------------------------------- Managed by Request Tracker
