[GRASS5] [bug #2690] (grass) System Response when no colortable is present
Mon Nov 15 07:07:39 EST 2004
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2690
> Subject: System Response when no colortable is present
> not really a bug, but a proposal for a message when importing
> Raster-maps without colortables. The Problem appears when importing a
> rastermap without a proper colortable. When trying to display this
> map, nothing appears on the screen even when setting the region to the
> imported map. The system should then give a message, that no
> appropriate colortable is present and give a hint to using r.colors.
> Especially for new users it might be a great help so that they can be
> sure, no errors occured during import and they additionally should set
> a colortable.
A map with no defined colour table should automatically use the
"rainbow" colour table.
If this isn't happening, file a bug report with details of how to
reproduce the problem.
