[GRASS5] [bug #2691] (grass) r.out.ascii parameter width doesn't work
Glynn Clements
glynn at gclements.plus.com
Mon Nov 15 07:12:52 EST 2004
Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=2691
> Subject: r.out.ascii parameter width doesn't work
> I tried to use the width parameter in r.out.ascii
> width = Number of values printed before wrapping a line
> but this feature doesn't work.
The width= option is only used when writing SURFER or MODFLOW format
(-s/-M switches); the GRASS format always writes one text row per map
row.
If that's intentional, it should be more clearly documented.
