[GRASS5] [bug #2691] (grass) r.out.ascii parameter width doesn't work
Markus Neteler neteler at itc.it
Wed Nov 17 09:45:01 EST 2004
On Mon, Nov 15, 2004 at 12:12:52PM +0000, Glynn Clements wrote:
> Request Tracker wrote:
> > this bug's URL: http://intevation.de/rt/webrt?serial_num=2691
> > Subject: r.out.ascii parameter width doesn't work
> > I tried to use the width parameter in r.out.ascii
> >  width = Number of values printed before wrapping a line
> > but this feature doesn't work.
> The width= option is only used when writing SURFER or MODFLOW format
> (-s/-M switches); the GRASS format always writes one text row per map
> row.
> If that's intentional, it should be more clearly documented.
In GRASS 5.7-CVS:
 I have changed the width parm documentation to reflect the "limitation".
 Also changed -M to -m for consistency.
Markus
