[GRASS5] Compiling my source
Damiano Triglione
damiano.triglione at polimi.it
Mon Nov 15 10:10:45 EST 2004
while I don't have any problem compiling Grass 5.4.0 sources, when it's the
turn to compile my little module there are some strange error messages that
I never encountered in Grass 4.x and 5.0b.
Let's make an example: I am in a directory where there are all my .c and .h
files, along with the Gmakefile. With older grass 5.0 when I type gmake5
everything goes ok. But with grass5.4 when I type gmake54 I have the
message:
bash: gmake54: command not found
So I realize that the command is in the build directory, so I type
/home/grass-build/gmake54
and now I have:
make: Entering directory '/home/damiano/mysrc/rr044'
make: *** no rule to make target 'dir'. Stop.
make: Leaving directory '/home/damiano/mysrc/rr044'
I cannot understand why it does not accept the Gmakefile present in rr044/
Of course my aim is to run it and debug it in the same folder. I do not want
that my executable will join immediately the folders of the binaries in my
Linux Mandrake 10 system!
Can anyone be so kind to help me, please?
Thanks,
Damiano
