[GRASS5] Re: vector point dataset
Gordon Keith
gordon.keith at csiro.au
Wed Nov 17 17:29:54 EST 2004
On Thu, 18 Nov 2004 01:22, Helena wrote:
> We have a project (with authors of r.terraflow) for computing massive DEMs
> and your data set looks like the size that we are aiming at, but there may
> be other bottlenecks in GRASS than gridding so we need to look at those
> too.
I'm working with bathymetry data from multibeam echosounders, typically
working with 10s of millions of points to create grids a few thousand by a
few thousand cells.
Is this project likely to be of interest to me (or vice versa)?
> >> A typical use for me, would be taking 120,000,000 point elevations and
> >> building a DEM. I have mainly used GMT for this, so hope to simply
> >> import the GMT netCDF grids (so far unsuccesfully)
I've basically given up on creating the DEM in GRASS and do all the work in
MBSystem, which generates GMT format grids.
I haven't been able to import GMT netCDF grids (haven't really tried) but have
no trouble importing grids in what MBSystem describes as
"GMT format id 1: Native binary single precision floats in scanlines with
leading grd header" using 'r.in.bin -hf'. I think MBSystem also describes
this format as "binary file (GMT version 1 GRD file)".
I'm not real familiar with GMT, but this might be of help to you.
Regards
Gordon
Gordon Keith
Programmer/Data Analyst
Marine Acoustics
CSIRO Marine Research
http://www.marine.csiro.au
God showed his love for us by sending his only Son into the world,
so that we might have life through him.
-- 1 John 4:9
