[GRASS5] Re: vector point dataset
Markus Neteler
neteler at itc.it
Thu Nov 18 10:54:31 EST 2004
On Thu, Nov 18, 2004 at 09:29:54AM +1100, Gordon Keith wrote:
> > >> A typical use for me, would be taking 120,000,000 point elevations and
> > >> building a DEM. I have mainly used GMT for this, so hope to simply
> > >> import the GMT netCDF grids (so far unsuccesfully)
> I've basically given up on creating the DEM in GRASS and do all the work in
> MBSystem, which generates GMT format grids.
> I haven't been able to import GMT netCDF grids (haven't really tried) but have
> no trouble importing grids in what MBSystem describes as
> "GMT format id 1: Native binary single precision floats in scanlines with
> leading grd header" using 'r.in.bin -hf'. I think MBSystem also describes
> this format as "binary file (GMT version 1 GRD file)".
> I'm not real familiar with GMT, but this might be of help to you.
Did you try a fresh GDAL (r.in.gdal then)?
http://gdal.org/frmt_various.html#netCDF
"This driver is primarily intended to provide a mechanism for grid interchange with the GMT package".
Markus
