[GRASS5] can't display vector maps
    Otto Dassau
    otto.dassau at gmx.de
    Thu Nov 18 03:52:26 EST 2004
Dear list,
I updated GRASS 5.7 from CVS this morning and can't display
vector maps anymore. I tried in several locations, with several maps.
I can see and select maps, but that's it.
GRASS 5.7.cvs:~ > g.list vect
vector files available in mapset PERMANENT:
archsites     soils           t_9961_300      t_county
bugsites      soistr          t_9961_300_all  t_hydro
fields        streams         t_9961_300_bks  t_powerlines
quads         t_9961_100      t_9961_400      tractids
roads
GRASS 5.7.cvs:~ > d.vect roads
ERROR: Vector file [roads] not available
the more detailed error messageusing the GIS Manager is:
child process exited abnormally
    while executing
"exec -- d.vect map=roads color=0:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape type=point,line,boundary,centroid,area icon=basic/cross size=5 fiel..."
    ("eval" body line 1)
    invoked from within
"eval exec -- $cmd $args >@ stdout 2>@ stderr"
    (procedure "run" line 2)
    invoked from within
"run $cmd"
    (procedure "DmVector::display" line 77)
    invoked from within
"DmVector::display $node"
    ("vector" arm line 2)
    invoked from within
"switch $type {
        group {
            DmGroup::display $node
	raster {
	    DmRaster::display $node
	labels {
	    DmLabels::display $node
    (procedure "Dm::display_node" line 6)
    invoked from within
"Dm::display_node $n"
    (procedure "DmGroup::display" line 11)
    invoked from within
"DmGroup::display "root""
    (procedure "Dm::display" line 6)
    invoked from within
"Dm::display"
    ("uplevel" body line 1)
    invoked from within
"uplevel \#0 $cmd"
    (procedure "Button::_release" line 18)
    invoked from within
"Button::_release .mainframe.topf.tb0.bbox1.b0"
    (command bound to event)
   Otto
