[GRASS5] can't display vector maps
Otto Dassau otto.dassau at gmx.de
Thu Nov 18 09:37:33 EST 2004
On Thu, 18 Nov 2004 09:52:26 +0100
Otto Dassau <otto.dassau at gmx.de> wrote:
> Dear list,
I checked again, installed GRASS CVS from scratch with the same result. I hope this is a minor bug and will be fixed soon, otherwise it is impossible to work with vector data.
I went back to CVS snapshot grass57_exp_2004_11_13, there it is still working.
  thanks
   Otto
> I updated GRASS 5.7 from CVS this morning and can't display
> vector maps anymore. I tried in several locations, with several maps.
> I can see and select maps, but that's it.
> GRASS 5.7.cvs:~ > g.list vect
> vector files available in mapset PERMANENT:
> archsites     soils           t_9961_300      t_county
> bugsites      soistr          t_9961_300_all  t_hydro
> fields        streams         t_9961_300_bks  t_powerlines
> quads         t_9961_100      t_9961_400      tractids
> roads
> GRASS 5.7.cvs:~ > d.vect roads
> ERROR: Vector file [roads] not available
> the more detailed error messageusing the GIS Manager is:
> child process exited abnormally
>     while executing
> "exec -- d.vect map=roads color=0:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape type=point,line,boundary,centroid,area icon=basic/cross size=5 fiel..."
>     ("eval" body line 1)
>     invoked from within
> "eval exec -- $cmd $args >@ stdout 2>@ stderr"
>     (procedure "run" line 2)
>     invoked from within
> "run $cmd"
>     (procedure "DmVector::display" line 77)
>     invoked from within
> "DmVector::display $node"
>     ("vector" arm line 2)
>     invoked from within
> "switch $type {
>         group {
>             DmGroup::display $node
> 	raster {
> 	    DmRaster::display $node
> 	labels {
> 	    DmLabels::display $node
>     (procedure "Dm::display_node" line 6)
>     invoked from within
> "Dm::display_node $n"
>     (procedure "DmGroup::display" line 11)
>     invoked from within
> "DmGroup::display "root""
>     (procedure "Dm::display" line 6)
>     invoked from within
> "Dm::display"
>     ("uplevel" body line 1)
>     invoked from within
> "uplevel \#0 $cmd"
>     (procedure "Button::_release" line 18)
>     invoked from within
> "Button::_release .mainframe.topf.tb0.bbox1.b0"
>     (command bound to event)
>    Otto
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
