[GRASS5] can't display vector maps
Markus Neteler
neteler at itc.it
Fri Nov 19 03:03:06 EST 2004
Hi Otto,
Radim submitted a bunch of bugfixes yesterday early evening:
http://grass.itc.it/pipermail/grass-commit/2004-November/date.html#end
Please update again. I just tested and things seem to work ok now.
GENERAL NOTES to update to current 5.7-CVS:
Probably there was a small bug in 'make mixclean' leaving
the links to 5.3 in the include/ directory. Please check
if grass57/include/ still contains links to GRASS 5.3-CVS
which is wrong. If links are still in existing in that
directory, run
find include -type l -exec rm {} \;
GRASS 5.7-CVS may no longer have links to 5.3-CVS.
Then:
make distclean
cvs up -dP
configure ...
make
make install
Hope this helps
Markus
On Thu, Nov 18, 2004 at 03:37:33PM +0100, Otto Dassau wrote:
> On Thu, 18 Nov 2004 09:52:26 +0100
> Otto Dassau <otto.dassau at gmx.de> wrote:
> > Dear list,
> Hi,
> I checked again, installed GRASS CVS from scratch with the same result. I hope this is a minor bug and will be fixed soon, otherwise it is impossible to work with vector data.
> I went back to CVS snapshot grass57_exp_2004_11_13, there it is still working.
> thanks
> Otto
> > I updated GRASS 5.7 from CVS this morning and can't display
> > vector maps anymore. I tried in several locations, with several maps.
> > I can see and select maps, but that's it.
> > GRASS 5.7.cvs:~ > g.list vect
> > vector files available in mapset PERMANENT:
> > archsites soils t_9961_300 t_county
> > bugsites soistr t_9961_300_all t_hydro
> > fields streams t_9961_300_bks t_powerlines
> > quads t_9961_100 t_9961_400 tractids
> > roads
> > GRASS 5.7.cvs:~ > d.vect roads
> > ERROR: Vector file [roads] not available
> > the more detailed error messageusing the GIS Manager is:
> > child process exited abnormally
> > while executing
> > "exec -- d.vect map=roads color=0:0:0 lcolor=0:0:0 fcolor=170:170:170 display=shape type=point,line,boundary,centroid,area icon=basic/cross size=5 fiel..."
> > ("eval" body line 1)
> > invoked from within
> > "eval exec -- $cmd $args >@ stdout 2>@ stderr"
> > (procedure "run" line 2)
> > invoked from within
> > "run $cmd"
> > (procedure "DmVector::display" line 77)
> > invoked from within
> > "DmVector::display $node"
> > ("vector" arm line 2)
> > invoked from within
> > "switch $type {
> > group {
> > DmGroup::display $node
> > raster {
> > DmRaster::display $node
> > labels {
> > DmLabels::display $node
> > (procedure "Dm::display_node" line 6)
> > invoked from within
> > "Dm::display_node $n"
> > (procedure "DmGroup::display" line 11)
> > invoked from within
> > "DmGroup::display "root""
> > (procedure "Dm::display" line 6)
> > invoked from within
> > "Dm::display"
> > ("uplevel" body line 1)
> > invoked from within
> > "uplevel \#0 $cmd"
> > (procedure "Button::_release" line 18)
> > invoked from within
> > "Button::_release .mainframe.topf.tb0.bbox1.b0"
> > (command bound to event)
> > Otto
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
Markus Neteler <neteler itc it> http://mpa.itc.it
ITC-irst - Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18 - 38050 Povo (Trento), Italy
