[GRASS5] Messages and GUI
Thu Nov 18 12:23:10 EST 2004
Hamish wrote:
> > > I was talking about when you hit the d.m "(re)draw" button on the left to
> > > draw whatever commands you have listed. there isn't necessarily a
> > > output window. Not the G_parser() gui windows, they work ok.
> > > Also it would run 0-100% many times for each map on the list..
> > So where does the process' output go in this case?
> in the main terminal window, even if I start with 'grass57 -gui'
In which case, GRASS_MESSAGE_FORMAT shouldn't be set to 'gui' when
performing redraw.
The setting should probably go into run_cmd in gui.tcl, so that
anything which is having its output processed by prnout uses the GUI
format, while everything else uses the terminal format. E.g.
	set env(GRASS_MESSAGE_FORMAT) gui
	if {[catch {open $cmd r} fh]} {
		unset env(GRASS_MESSAGE_FORMAT)
		error $fh
		fconfigure $fh -blocking 0
		fileevent $fh readable [list prnout $dlg $fh]
