[GRASS5] Messages and GUI
Hamish
hamish_nospam at yahoo.com
Thu Nov 18 02:10:17 EST 2004
> > I was talking about when you hit the d.m "(re)draw" button on the left to
> > draw whatever commands you have listed. there isn't necessarily a
> > output window. Not the G_parser() gui windows, they work ok.
> > Also it would run 0-100% many times for each map on the list..
> So where does the process' output go in this case?
in the main terminal window, even if I start with 'grass57 -gui'
Hamish
